How you live in your home and how you clean and maintain your home affect the quality of air in your home. Keeping your home clean and dry makes it comfortable and healthy for you and unfriendly and unwelcoming to pests.
The Building Connection
Housing and Asthma
Asthma is a serious disease that affects millions of Americans, particularly children. Asthma is also increasing at an alarming rate. Many air pollutants are found at higher levels indoors than outdoors. Among them are the most common asthma triggers: particles from molds, dust mites, mice, rats, roaches and pets.
Indoor air contains other pollutants such as carbon monoxide, volatile organic compounds (chemicals released from materials), nitrogen dioxide, sulfur dioxide, radon and other particles that can make people sick or make asthma worse.
Some indoor air pollutants come from outside. These include ozone, sulfur dioxide, carbon monoxide, pollens and other particles that can also make people sick or make asthma worse.
What you bring into your home, how you live in your home and how you clean and maintain your home affect the quality of air in your home. You can control many of these sources of pollution that otherwise can make you sick or make your asthma worse.
The Seven Steps to a Healthy Home
There are seven steps to a healthy home. A healthy home is:
- Dry
- Clean
- Well Ventilated
- Combustion Product Free
- Pest Free
- Toxic Chemical Free
- Comfortable
How you live in your home affects each of the seven steps. Water, clutter and dust provide the conditions and ingredients for mold, insects, mice, rats, roaches and dust mites to make their home in your home. Pests inside your home can lead to allergic reactions; pests lead to the use of pesticides that are not good for people to breathe or ingest (eat). Food and water are an invitation for pests to live in your home. If you keep your home clean and dry you will have a home that is healthy and comfortable for you at the same time that it is not a friendly place for these unwelcome pests.
Ventilation removes stale air from your home and brings fresh air inside. This helps to remove some of the pollution that builds up inside your home. But you have to use the fans or ventilation system to keep your home from becoming stale and unhealthy. If ventilation is inadequate, moisture can build up increasing the humidity in your home. High humidity levels make the air feel sticky and uncomfortable for most people. Mold and dust mites, however, love high humidity. So comfort, no pests and good indoor air quality go hand in hand.
Burning gas or oil produces combustion products such as carbon monoxide — these should never be present in a healthy home. Smoking is a form of combustion; so don’t let anyone smoke inside your home. Keep your home a healthy home.
What people bring into homes and store inside can often lead to problems. The containers that store toxic chemical cleaning compounds, solvents and oil-based paints slowly release the chemicals into the indoor air. Don’t bring these products into your home. When in doubt, get them out by disposing of them properly.
Living in Your Healthy Home
Getting Started
The first thing is to do is to learn about your home. Familiarize yourself with the operation of all appliances and equipment. Learn where the main water and gas shut off valves are. Learn where the electrical panel is and which switch turns off the electrical power. Learn how to turn off the water to the clothes washer and to the hot water tank in case a hose bursts or they begin to leak.
Probably the most important thing to learn about your home is how to report problems and to report them right away. If a leaky pipe leaks a little bit for a long time major problems can occur.
Dry
Too much water in your home is bad. Too much water results in mold, insects, rodents and mites. Remember that a healthy home is a dry home.
One of the worst things you can do is use a humidifier. Humidifiers add uncontrolled amounts of water to indoor air. They also have to be cleaned each week.
If you must use a humidifier – don’t – use a vaporizer.
If you must use a vaporizer, if we can’t convince you not to use one, keep the interior relative humidity below 30 percent in the winter. To monitor humidity you need a measuring device called a hygrometer. Clean the vaporizer regularly if you use it.
If you have bathroom fans use them when you are in the bathroom, especially when showering. They remove water from bathrooms.
If you have a kitchen fan use the fan when you are cooking. Especially when you are cooking with water. Boiling water is a humidifier. And you already know how we feel about humidifiers.
If you have a clothes dryer, make sure it is vented to the outside. If you vent it inside it is a humidifier…and you already know how we feel…
Plumbing leaks need to be fixed – right away. Find out how to shut off your water if you have a leak. Report the leak and insist that it get fixed. Be a pest. It’s important.
Leaking clothes washers and leaking hot water tanks can be a major headache and need to be fixed right away.
Basements are often damp. Don’t store anything in a damp basement. Mold will probably grow on what you store in a damp basement. If your basement is damp run a dehumidifier.
Don’t open your basement windows in the summertime, the basement will only get wetter. Outside air in the summertime is humid and the moisture in it will condense on cold basement walls the same way water condenses on the outside of a cold glass.
If you have a dry basement and you want to store stuff in it – don’t. But if you must, use wire or plastic racks or shelving that elevates things above basement floor slabs and allows lots of air circulation. Don’t let any paper or cardboard touch the floor or a wall. Better still, don’t store any paper products or fabrics in your basement. Use sealable plastic containers.
While we are talking about storage, don’t store things in attics either. This advice only applies to attics without floors. It’s important that attics are well ventilated and storing things in attics interferes with air flow and also probably causes problems with attic insulation. The only thing that should be in your attic is air – and insulation.
If you have gutters or downspouts, keep them clean. Don’t disconnect gutters and downspouts. Keeping water away from the walls helps keep your basement dry.
And finally don’t install wallpaper in your home. Why? Wallpaper keeps walls from drying if they get wet – especially vinyl wallpaper. Trapped moisture allows mold to grow.
Clean
Dust is bad; it contains asthma triggers. Over two thirds of dust in homes originates outdoors, and is tracked in on feet. House dust is known to contain many hazardous materials. Stop the dust at the door. Take off you shoes and provide a space for your shoes at the door. Provide a welcome mat and keep it clean. Vacuum and filter the rest away. And make the home easy to clean. Don’t clutter your home.
A good trick is to have a pair of inside shoes and a pair of outside shoes.
Use a vacuum regularly. If you can afford one, get a vacuum with high efficiency filtration and an embedded dirt detector (it indicates when the floor is clean). Check the bag regularly. Replace the bag when necessary.
When you use cleaners use mild cleaners and soaps. Don’t turn the area under your sink into a toxic chemical dump by storing powerful chemical cleaners. Don’t store pesticides there.
Change your furnace filter regularly – or insist that it be changed. Filters should be rated at MERV 6-8 (35 percent or better dust spot efficiency).
Don’t use or purchase an ozone air cleaner. Ozone is a respiratory irritant and can trigger asthma attacks. And while we are at it, don’t use air fresheners or room air deodorants. They are indoor air pollutants that mask problems and deaden the senses if they are not causing respiratory problems on their own.
Well Ventilated
Dilution is the solution to indoor pollution that cannot otherwise be prevented or removed.
Almost everything in your home gives off chemicals or moisture. If there are too many pollutants in the air that you breathe you have a problem. Since people love their possessions and we can’t get rid of their possessions or find possessions that don’t give off pollutants we have to ventilate the pollutants in the indoor air out.
Oh by the way, people also give off stuff – moisture, odors, carbon dioxide….we’ll stop the list here because it can get pretty ugly. So even in a house without stuff, the people in the house need ventilation air to dilute the “bio- effluent” they themselves generate. People also cook – well some of them do – and generate more stuff. You get the picture.
Use your bathroom fans, when you are in the bathroom and after showering.
Use your kitchen fan when cooking.
Open your windows when it is not too cold (or when it is not too hot or humid if you have air conditioning).
When you are cleaning, especially with powerful cleaning agents (the stuff we told you not to store under your sink), open your windows and turn on an exhaust fan.
If you can, ventilate your dry cleaning before you hang it in your closet. Air it out outside if you can. Or on a porch, or in your garage. Or in a room with an open window. Better still buy clothes that don’t need to be dry cleaned. Some “dry clean only” clothes can be washed – but be careful.
Combustion Free
When something is burned it produces products of combustion, particularly carbon monoxide and particles that are unhealthy. Products of combustion should never be found in the indoor air of a healthy home.
Don’t smoke in a healthy home.
Don’t burn candles in a healthy home – at least not the scented ones. The aromatic candles generate soot and other bad stuff (chemicals that are not good to breathe). . .
