Westford, MA —Westford Modern Colonial Deep Energy Retrofit - Case Study
Westford, MA
Project Team: Basnett Design/Build/Remodel, Contractor; Building Science Corporation, Consultants and DER Technical Support; National Grid, Massachusetts, DER Pilot Program Administrator/Sponsor
Description: Major renovation including partial DER of 3,955 ft2 four bedroom, two full and one half bathrooms, three stories plus a partially finished full basement
Completion Date: December 2011
Estimated Annual Energy Savings: Projected 29% source energy use reduction compared to pre-retrofit conditions
Air barrier system at eave
Domestic hot water heater
Lighting: CFL lighting.
Energy Star® washer and dryer
Design Challenge: Isolating an Attached Garage
This house has an attached 2-car garage with the master bedroom located directly above. For a project with super-insulation and significantly improved air tightness goals, this condition requires special care. To ensure air separation between the garage and the interior of the house, the air barrier layer of the house at the separation wall and at the garage ceiling requires careful detailing and air tight transitions. For the best thermal performance, there should be no thermal bridges between the garage enclosure and the house enclosure.
For this project, the builder was able to completely isolate the front and rear garage walls from the exterior wall of the house. With the siding for the garage removed, the garage wall sheathing and wall framing was cut back creating an opening between the garage walls and the house exterior wall. The air barrier and exterior insulation layers of the exterior wall of the house were then extended continuously through the garage wall connections.
Percent Energy Use Reduction
26
Insulation
